03-03-2013 10:14 PM - edited 03-16-2019 04:02 PM
Hello, gents.
I have a CUCM 6.1 plus gateway with 2 working E1 channel. By the request of a bussines i trying to add one more E1.
At the CUCM page i already has a two VWIC2-2MFT-T1E1-E1 cards (subunits). I just go to E1 0/1/0 and adjust settings via web (equal to working E1).
On other side, at my Cisco 3845 gateway i have added ;
card type e1 0 0
card type e1 0 1
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-select 1 E1 0/0/0
network-clock-select 2 E1 0/0/1
network-clock-select 3 E1 0/1/0
controller E1 0/0/0
pri-group timeslots 1-31 service mgcp
controller E1 0/0/1
controller E1 0/1/0
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:15
no ip address
encapsulation hdlc
no cdp enable
interface Serial0/1/0:15
no ip address
encapsulation hdlc
no cdp enable
voice-port 0/0/0:15
cptone RU
voice-port 0/0/1:15
cptone RU
voice-port 0/1/0:15
cptone RU
ccm-manager shut-backhaul-interfaces
ccm-manager redundant-host 10.76.130.10 10.76.230.10
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 10.76.130.10 10.78.130.10 10.76.230.10
ccm-manager config
mgcp
mgcp call-agent 10.78.130.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode nte-ca
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
mgcp package-capability fm-package
mgcp default-package fxr-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback1
mgcp bind media source-interface Loopback1
mgcp behavior g729-variants static-pt
mgcp profile default
sccp local Loopback1
sccp ccm 10.78.130.10 identifier 781 version 4.1
sccp ccm 10.76.230.10 identifier 762 version 4.1
sccp ccm 10.76.130.10 identifier 761 version 4.1
sccp
sccp ccm group 1
bind interface Loopback1
associate ccm 761 priority 1
associate ccm 762 priority 2
associate ccm 781 priority 3
So now i see at CUCM gateway tab:
Registration Unregistered
at gateway side i see:
1) sh isdn status
Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 2. Layer 3 output may not apply
ISDN Serial0/1/0:15 interface
dsl 2, interface ISDN Switchtype = primary-net5
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
SHUTDOWN
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 2 CCBs = 0
The Free Channel Mask: 0x00000000
Number of L2 Discards = 0, L2 Session ID = 1
Total Allocated ISDN CCBs = 0
In reality psycis is connected.
2) sh controllers e1
E1 0/1/0 is down.
Applique type is Channelized E1 - balanced
Cablelength is Unknown
Description: ** New E1 **
Transmitter is sending remote alarm.
Receiver has loss of frame.
alarm-trigger is not set
Version info Firmware: 20090408, FPGA: 13, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (743 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 743 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
My question is : what should i do and what i made wrong ?
03-04-2013 01:05 AM
it seems your E1 is shutdown or your link is not connected
Anas
please rate if it is helpful
Sent from Cisco Technical Support Android App
03-04-2013 04:27 AM
Hi, gents.
I have fixed issue.
I trying for test to set a NO CRC4 and new E1 is registered.
So finally i asked a carrier to enable a CRC4 from their side. So set CRC4 + Reset gateway from CUCM and e1 is registered
