Hide calling name for specific calls (internal)
f-vanryckeghem
This  is  what  I  would like to  configure.
All the phones belonging to  a partition ( Internal_guest) may  call each other,  but when calling,  the calling  party name and called party name should not  appear on the phone.
But when calling phones in another partition ( Reception),  the callin/called party name should be present on the phone.
I  have tried several things with transformation pattern but ..no  result
Thanks a lot  for any hint
Frederic
Ayodeji Okanlawon
You will need a xlation pattern to achieve this. On the xlatipn pattern you can then set the calling name presentation to restricted and the connected name presentation to restricted.
Please rate all useful posts
