NXAPI in MDS 404 Not Found
pradsrin
In MDS device we were not able to post data in below mentioned URL, We were get 404 Error
https://xxx.xxx.xxx.xxx:630/api/mo/sys.json
But the same URL, we were able to successfully post data in N9K device.
We have followed the below mentioned steps to make sure NXAPI was enabled in MDS
Enabled NXAPI feature
Enabled Https Port
Configured with new port number
Note : In both MDS and N9k, we were able to successfully post data in https://xxx.xxx.xxx.xxx:630/ins
So we doubt whether the below mentioned url is only supported in N9k?
Sergiu.Daniluk
MDS does not look to support REST MIB based APIs. It only lists as NX-API CLI:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/8_x/programmability/cisco_mds9000_programmability_guide_8x/nx_api.html
Have a look at the Nexus vs MDS supported APIs: https://developer.cisco.com/site/cisco-nexus-nx-api-references/
Btw, you can use sandbox for testing supported APIs on both platforms: after you enable feature nxapi, connect in a browser to https://<mgmt-ip-address>/ and you will see all available apis.
Stay safe,
Sergiu
