Cisco Spark Proximity - AudioPairing - self token not decoded
STEVEN READ
Hi all,
I have a Cisco MX700 registered to the Cisco Spark cloud, and I'm seeing this error (on the touch panel) when running the Sound Test.
Unable to verify device pairing capabilities
"Unable to detect the ultrasound signal which enables pairing between the video system and your phone or laptop"
I've looked into the usual places, and not seeing any info on this error. I haven't come across this before
Any one seen this error, or know what can be done to fix.
Rgds
Steve
Wayne DeNardi
If you don't need Proximity, you can just disable it with the command
xConfiguration Proximity Mode: Off
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
JFerello
Steven,
Did you ever figure this out, I am running into the same issue and I disabled Proximity.
Justin
Justin Ferello
@STEVEN READ
Steven,
had the issue been solved or still existing?
Can you please share the workaround that help you in solving this issue, in case you solved it?
