cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Orphan device in vPC domain
anderson327
Hi community,
I have a doubt with the next:
I have a topology with a vPC domain, two switches Nexus in core layer and 4 nexus in access layer. Additionally, I have a switch catalyst that I need to keep in the topology connected to a trunk to one of the access layer nexus. Does this switch catalyst under its condition as an orphan device require any specific configuration in yours ports to establish the trunk with the nexus?
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Hi Anderson
Yes you have to configure LAG on the Nexus, between the Nexus you need VCP and LAG on the catalyst switch to make it works.
For example:
Nexus
interface e100/1/10
channel-group 2 mode on
no shutdown
int po 2
switchport mode trunk
vpc 2   <--------- used between the Nexus only.
speed 1000
no shutdown
**Similar on Nexus 2.
CATALYST SWITCH
interface g1/1/1
no shut
int po2
no shut
**The same for the interface connected to Nexus 2.
Hope it answered the question.
Regards.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Ver la solución en mensaje original publicado
1 RESPUESTA 1
Hi Anderson
For example:
Nexus
interface e100/1/10
no shutdown
int po 2
speed 1000
no shutdown
CATALYST SWITCH
interface g1/1/1
no shut
int po2
no shut
Regards.
