02-19-2016 03:13 PM - edited 03-17-2019 05:58 AM
Hi there,
Thanks for reading.
We have ISR4431s with PVDM4-64s installed but we're not interested in those billing stats. Is there a way to disable that only? Here's an example:
Feb 19 14:39:20.354: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId FFFFFFFFE546C545FFFFFFFFE2000A1F81B50494E6F7C05, SetupTime 14:38:44.914 UTC Fri Feb 19 2016, PeerAddress , PeerSubAddress , DisconnectCause 0 , DisconnectText , ConnectTime 14:38:44.914 UTC Fri Feb 19 2016, DisconnectTime 14:39:20.354 UTC Fri Feb 19 2016, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
Feb 19 14:39:20.354: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:02/19/2016 14:38:44.908,cgn:,cdn:,frs:0,fid:222120,fcid:0000,legID:37E57,bguid:00000000000000000000000000000000
Feb 19 14:39:20.354: VOIP_CALL_STATISTICS:DSP/TX: PK=0, SG=0, NS=0, DU=0, VO=0
DSP/RX: PK=0, SG=0, CF=0, RX=0, VO=0, BS=0, BP=0, LP=0, EP=0
DSP/PD: CU=0, MI=0, MA=0, CO=0, IJ=0.0000
DSP/PE: PC=0, IC=0, SC=0, RM=0, BO=0, EE=0
DSP/LE: TP=0, TX=0, RP=0, RM=0, BN=0, ER=0, AC=0
DSP/ER: RD=0, TD=0, RC=0, TC=0
DSP/IC: IC=0
My boss wants to be rid of the DSP stats. Is there a way to toggle this?
Thanks!
Bob
02-20-2016 06:29 AM
Please post your config.
02-21-2016 05:48 AM
Hi Bob,
I think in your config you have the command 'gw-accounting syslog stats'. Try to remove it and add 'gw-accounting syslog' without 'stats' keyword
02-22-2016 01:50 PM
Hi Mohammed,
Thanks for your help! I need to jump through some Change Management hoops on my side but will reenter the command without the STATS keyword and let you know the outcome.
Thanks again,
Bob
