03-29-2021 08:50 AM
Hi Friends.
Cisco 9300-24T switch is not detecting the SFP-10G-ER.
IOS Version: 16.12.4
service unsupported-transceiver is enabled
error disable detect cause gbic-invaild is disabled
Even the SFP module is not showing when show interface transceivers.
Suggestion's are most welcome.
Solved! Go to Solution.
03-30-2021 02:10 PM
post the complete logs when you installing SFP
also check the compatible matrix : (i did not find it supported in Cat 9300 - some data may be wrong?)
03-29-2021 12:13 PM
C9300L-24T-4G—24 1-GE ports
C9300L-24P-4G—24 1-GE ports
C9300L-24T-4X—24 10-GE ports
C9300L-24P-4X—24 10-GE ports
what model?
03-29-2021 12:59 PM
Switch Ports Model SW Version SW Image Mode
* 1 41 C9300-24T 16.12.4 CAT9K_IOSXE INSTALL
2 41 C9300-24T 16.12.4 CAT9K_IOSXE INSTALL
Uplink module is NM-8X
03-29-2021 08:31 PM
what uplink module you have ? is this a Cisco SFP ? if not try below :
no errdisable detect cause gbic-invalid
03-30-2021 01:03 PM
Uplink module is Cisco C9300 NM-8X and SFP is Cisco SFP-10G-ER.
I tried below cmd still its not detecting.
03-30-2021 01:46 PM
pls copy-paste here show ver , show inv
03-30-2021 02:10 PM
