Cisco wireless controller 2504
yousefabd1415
Dear all ,
I want to support me I have wireless controller 2504 connect to device access point but I can not enter webpage so I want configuration this device but I can not enter webpage
Best regards
balaji.bandi
If you like to manage WLC using connection Wireless network you need to enable Management over Wireless. (but before enable think that all devices connected over wireless can access the GUI, that will be security risk)
if you can SSH to WLC using CLI:
config network mgmt-via-wireless enable.
Via GUI: (if you can access using LAN)
Management > Mgmt Via Wireless and enable this check box and apply.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/administration_of_cisco_wlc.html?bookSearch=true
BB
