取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
7821一直Registration in progress
tony_tan
各位老师,话机前几天还正常使用,今天上班后一直显示Registration in progress,看debug voice register even 和debug tftp event如下,请各位老师指点
May 14 18:44:08: TFTP: Looking for SEP80E86F238274.cnf.xml
May 14 18:44:08: TFTP: Opened flash:/its/SEP80E86F238274.cnf.xml, fd 11, size 4818 for process 163
May 14 18:44:10: TFTP: Looking for SEP80E86F238274.cnf.xml
May 14 18:44:10: TFTP: Opened flash:/its/SEP80E86F238274.cnf.xml, fd 12, size 4818 for process 188
May 14 18:44:14: TFTP: Looking for SEP80E86F238274.cnf.xml
May 14 18:44:14: TFTP: Opened flash:/its/SEP80E86F238274.cnf.xml, fd 13, size 4818 for process 291
May 14 18:44:18: TFTP: Looking for SEP80E86F238274.cnf.xml
May 14 18:44:18: TFTP: Opened flash:/its/SEP80E86F238274.cnf.xml, fd 14, size 4818 for process 305
May 14 18:44:37: TFTP: Finished flash:/its/SEP80E86F238274.cnf.xml, time 00:00:30 for process 64
May 14 18:44:38: TFTP: Finished flash:/its/SEP80E86F238274.cnf.xml, time 00:00:30 for process 163
May 14 18:44:40: TFTP: Finished flash:/its/SEP80E86F238274.cnf.xml, time 00:00:30 for process 188
May 14 18:44:44: TFTP: Finished flash:/its/SEP80E86F238274.cnf.xml, time 00:00:30 for process 291
May 14 18:44:48: TFTP: Finished flash:/its/SEP80E86F238274.cnf.xml, time 00:00:30 for process 305
May 14 18:46:16: TFTP: Looking for ITLSEP80E86F238274.tlv
May 14 18:46:20: TFTP: Looking for ITLSEP80E86F238274.tlv
May 14 18:46:24: TFTP: Looking for ITLSEP80E86F238274.tlv
May 14 18:46:36: TFTP: Looking for ITLFile.tlv
May 14 18:46:37: TFTP: Looking for ITLFile.tlv
May 14 18:46:39: TFTP: Looking for ITLFile.tlv
May 14 18:46:43: TFTP: Looking for ITLFile.tlv
May 14 18:46:47: TFTP: Looking for ITLFile.tlv
512049152 bytes total (196763648 bytes free)
May 14 18:46:59: TFTP: Looking for SEP80E86F238274.cnf.xml
May 14 18:46:59: TFTP: Opened flash:/its/SEP80E86F238274.cnf.xml, fd 10, size 4818 for process 64
May 14 18:47:00: TFTP: Looking for SEP80E86F238274.cnf.xml
May 14 18:47:00: TFTP: Opened flash:/its/SEP80E86F238274.cnf.xml, fd 11, size 4818 for process 163
May 14 18:47:02: TFTP: Looking for SEP80E86F238274.cnf.xml
May 14 18:47:02: TFTP: Opened flash:/its/SEP80E86F238274.cnf.xml, fd 12, size 4818 for process 188
May 14 18:47:06: TFTP: Looking for SEP80E86F238274.cnf.xml
May 14 18:47:06: TFTP: Opened flash:/its/SEP80E86F238274.cnf.xml, fd 13, size 4818 for process 291
May 14 18:47:10: TFTP: Looking for SEP80E86F238274.cnf.xml
May 14 18:47:10: TFTP: Opened flash:/its/SEP80E86F238274.cnf.xml, fd 14, size 4818 for process 305
May 14 18:47:29: TFTP: Finished flash:/its/SEP80E86F238274.cnf.xml, time 00:00:30 for process 64
May 14 18:47:30: TFTP: Finished flash:/its/SEP80E86F238274.cnf.xml, time 00:00:30 for process 163
May 14 18:47:32: TFTP: Finished flash:/its/SEP80E86F238274.cnf.xml, time 00:00:30 for process 188
May 14 18:47:36: TFTP: Finished flash:/its/SEP80E86F238274.cnf.xml, time 00:00:30 for process 291
May 14 18:47:40: TFTP: Finished flash:/its/SEP80E86F238274.cnf.xml, time 00:00:30 for process 305
4 条回复4
tony_tan
求大神出现:P
Rockyw
楼主看看下面的两篇文档有没有帮助
Solved: 7821 Registration issue
https://community.cisco.com/t5/ip-telephony-and-phones/7821-registration-issue/td-p/2465305
Solved: Cisco 7821 don't registered on CUCM 9.1
https://community.cisco.com/t5/ip-telephony-and-phones/cisco-7821-don-t-registered-on-cucm-9-1/td-p/2979974
Rockyw | If it solves your problem, please mark as answer. Thanks !
tony_tan
Rocky 发表于 2020-5-18 23:37
楼主看看下面的两篇文档有没有帮助
https://community.cisco.com/t5/ip ...
你好第一个连接打开后没有找到相关内容,第二个可以打开,但我没有与CUCM 集成,感谢你的支持,虽然还没有解决问题,还是非常感谢您的
tony_tan
等待大神指点:)
快捷链接
