02-02-2018 06:30 AM - edited 03-01-2019 05:26 AM
i have a Strange request and i would like to get an advice about it.
I have implemented a Dual Site ACI Fabric : DCI is a back to back (vpc) via DWDM.
The question from my Customer is : is it possible to establish a L2TP tunnel between a VRF define in the left side ACI Fabric and another VRF defined in the right side ACI Fabric ?
We tried to bypass an issu we have with PVLAN that can't be extended between teh two ACI Fabrics : the flows from an Isolated VM (PVLAN x) in left ACI Fabric side can't reach a VM (standard VM (not PVLAN isolated) in the other (right ) Datacenter. because retrurning flows are dropped...on DCI
Thanks a lot for your help
02-02-2018 12:25 PM
Have you looked into the "Common Pervasive Gateway" Feature in ACI?
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/kb/b_KB_Common_Pervasive.html
02-02-2018 11:22 PM
yes Pervasive GW is working fine. It is not my question.
My question is : is L2TP feature configurable into an ACI (between 2 VRF located in two Dual Site ACI Fabrics) ?
Thanks a lot for your help.
