Layer 3 Out VPC
MJU-NETDESIGN
Hi there
I have 2 pods each with 2 Border Leaf.
On each 2 Border Leaf im trying to connect a Firewall with a layer 3 VPC. (/28 for glue/transport net)
I have one VRF with one bridge domain, and servers in that bridge domain must use the external firewall to reach internet.
Is this a supported way to connect 2 5510 Firewall ??
PatrickH1
sure you can so it, but the Design depends a little bit from the Firewall Setup. Is it a Acitve/Active or Active/Standby Cluster.
Set a default route to the Firewall and assign a contract between the Layer3Out Firewall and the EPG Provider -> Consumer.
Here is a White Paper about : Cisco ACI Multi-Pod and Service Node Integration
https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/application-centric-infrastructure/white-paper-c11-739571.html
If this is helpful, mark it as helpful :)
Kind Regards
Patrick
