SNMP monitoring in ACI
Harish Chopra
My question is related to the snmp monitoring for ACI.
1. what I understand, earlier ACI didn't supported snmp but with the latest Brahmaputra release does it supports snmp now ?
2. Can we monitor the nexus switches individually from any monitoring platform when the nexus 9k is running in ACI mode. if yes, then how ? using snmp or REST API like the way we monitor - APIC controllers. I understand that if I add the APIC controller then it automatically fetches the information about all the nexus switches in the Pod but what if we have
Harish
Tomas de Leon
Harish,
SNMP has been supported on the ACI Leaf & Spine nodes since version 1.0 FCS.  APIC SNMP support will be in the Brazos release coming soon.
I have enclosed a document that I put together that may help with the things that you want.
Cheers!
T.
