Jabber 10.5.1 and later Built in Web Browser
EU UC Support
Level 4
Level 4
Has the built in browser changed for plugins on Jabber versions 10.5.1 .2 and 10.6? I am getting an error message, browser IE5 not supported when going to a plugin. On older versions 10.5.0 and below this works.
Olly.
jocreed
Olly, I just want to confirm that you are using Internet Explorer 5. Is that correct?
Jock
I also have issue after Jabber 10.5.0 (that is the last version that works)
I do not get an error but our intranet pages don't load proper and the scrolling does not work.
Did some testing with public internet sites and those seem to work.
If I downgrade to v 10.5.0 everything works fine.
anyone have any ideas?
thanks
-Alex
Alex,
Can you give some more specifics about your problem and your environment?
What browser or browsers are you utilizing?
What is the exact operating system and version?
What link are you downloading Jabber from?
Do you have an internal DNS server configured for your network?
Can you describe your network configuration in a little more detail?
Have you configured your certificates and / or revocation server properly?
Please contact us back with a few more details.  If it does get a lot more detailed or involved as far as the problem you will have to open a support ticket.
Thank You,
Jock
