Jabber for iOS native directory match on incoming call
Apologies if this topic has already been discussed.
Is there a plan to add the capability of native contact resolution in incoming call on Jabber for iOS? I mean, resolution of calling number into calling name using iPhone/iPad directory and not Jabber contacts.
Thanks.
Filippo Zangheri
jocreed
Filippo,
According to our team here this should already work – assuming the user enabled access to native contacts after initial install.
Are you experiencing this not working?
Let me know if you have any other questions.
Thank You,
Jock
jocreed
I do not think this is in the plan for Jabber for iOS.  But let me check in to this and I will get back with you.
Filippo,
I contacted some people to see if this can be added as a feature enhancement.  I will let you know how that goes when I find out something.
Thank You,
Jock
jocreed
Filippo,
Thank You,
Jock
Jock,
Sorry for the late reply. Tested Jabber for iPad v.11.0.1 and it works smoothly -- only caveat is that when you add a new contact, you have to restart Jabber (or wait for some unknown amount of time) in order for it to pick up the new contact.
Thank you very much.
Filippo
