01-07-2014 05:05 PM
I'm looking into the viability of using the Jabber SDK with cloud-based Jabber (WebEx Connect). Is this possible? I see in the below deployment guide, it mentions pointing to a Jabber URL but I have no idea where you would point in the case of jabber-cloud.
Brian
UC network guy
01-07-2014 06:53 PM
Brian,
Yes, there is a set of SDK that supports cloud-based Jabber. You can download the SDK here
Once downloaded, extract the SDK and modify the configuration as below in the sampleclient.html to connect to your Webex Connect account.
var demo_config = {
httpBindingURL: "https://im1.ciscowebex.com/http-bind", //Your Webex Connect BOSH URL, should be im1 or im5
domain: "cisco.com", // The domain name assigned by webex connect
maxGraphAge: 5,
unsecureAllowed: false,
atSymbolAllowed: false,
logPersistence: false
Howard
01-08-2014 11:09 AM
Hi Howard,
Thank you! That's exactly what I was looking for.
Best Regards,
Brian
02-03-2014 04:33 AM
Is desktop share supported when using SDK for webexconnect?
02-03-2014 04:50 AM
also wondering if desktop control is supported as well in this scenario. Remote expert request control of desktop as supported today in webexconnect.
02-03-2014 07:49 AM
The SDK does not currently support desktop share. It's on the roadmap, but no scheduled time can be confirmed.
Howard
