Hello Dear, I need your help, I have to install model c9105axi-a APs, but I see that these are recommended only for offices, not to be a high-rise installer, the issue is that the client is requesting to install APs in the access hall At a height of 15 meters (49 feet), my query is:
- What is the maximum installation height of these APs?
- If you install them, will I have coverage problems?
