Devnet for Voice infrastructure/Voice Gateway
Ishan Sambhi
Hi Team,
My customer has a question around being able to automate configuration of CUBE's. They deploy CUBEs in mass and want to be able push configuration to the CUBE routers(mainly ISR 4k -> CAT 8K) using Ansible.
Any experience around this?
Ishan
Alex Stevenson
Hello @Ishan Sambhi,
I noticed the website DevOps Cube had a recent article this month titled 19 DevOps Tools for Infrastructure Automation and Monitoring (https://devopscube.com/devops-tools-for-infrastructure-automation/). Ansible is #3 on their list and they specifically mention Ansible Galaxy as a place to find all community playbooks from Ansible. From there, I found the following:
Ionoscloud : The Ansible module of the Ionos Cloud API ( https://galaxy.ansible.com/ionoscloudsdk/ionoscloud).
After installing, make sure to check out the Ansible model for IonosCloud API on GitHub (https://github.com/ionos-cloud/module-ansible)
Hope this helps!
