Dockerizing a JTAPI Application
Hello all,
I am new to JTAPI and have briefly looked through the documentation. I was wondering if anyone here is aware of any issues/limitations with dockerizing a JTAPI application that will be focused on monitoring call events and allowing limited call control.  Any help you could provide would be greatly appreciated.
mpotluri
Level 5
Level 5
Though this is not tested I don't expect to see any issues as long as the docker container has network connection to CUCM. You can use one of the sample apps to verify it.
Hello Mohan, Could you tell me where I find one of the sample apps?
There are 2 sample apps (JTrace and makecall) that comes with Cisco JTAPI installation. After you install Cisco JTAPI you should see these 2 in apps in your installation folder.
There is another Cisco JTAPI test tool which show cases the capability of Cisco JTAPI API and can be found at Cisco JTAPI.
