How to Set Conference Password for Meetme Bridge
rilenp2006
hi,
can anyone help me to set conference password to login meetme Bridge using TCL Scripts,
Details:
CCME 4.1
IOS :12.4(15)T1
cisco 3825 ISR Router.
Rgards,
Chaitanya D
20 Replies 20
Raghavendra G V
Hi Chaitanya,
how you are trying to set the password? could you please explain more what you are trying to do?
Raghavendra
hi Raghavendra,
i have crated a  meet me conference Bridge in my CCME router, i want anyone login to this bridge using PIN number
1) dialing conference Bridge number
2) announcment will be played for entring PIN number
3) after enterning PIN only it should connect to conference
4)if PIN is not corrcet it will play announcment to Retry
Hi Ragavendra,
i have created meet me conference Bridge in my CCME Router 3825
senario is like
1) if anyone want to join confrence Bridge dial bridge number
2)play announcment to enter conference PIN
3)if PIN is correct connect to Conference
4)if PIN is wrong Paly announcment to enter correct password
Like wise..
Chaitanya
hi raghavendra,
the senario i have mentioned above need to be created using tcl script, for this only i am requesting for help,
because i am not good at that.
Hi Chaitanya,
Attached TCL script will cover your requirements, you can modify it accordingly.
Raghavendra
hi Raghavendra,
can you tell me the procedure how do i map this script to meetme dn number: 44567, i have uploaded them to flash, but how do i map this script to perticular number in cisco cme, 15.1 IOS cme 8.0
To invoke your TCL script, you need to configure the application and then associate the application to inbound dial peer.
for example :
config t
  application
      service password2call flash:password2call.tcl
        param enter-pw-prompt flash: < any audio file >
        param password1 <password>
  dial-peer voice 1 voip
for more information you can refer TCL IVR Videos and programming guide in below link
https://developer.cisco.com/site/collaboration/call-control/voice-gateway/documentation/
Raghavendra
Hi raghavendra,
i have configured the steps which you have given, but problem is my conference bridge number is 78928,
how do i mapp the script to this perticular number, even now also i dial to 78928 no meesage is playing its dierectly connecting
did you configured script under the correct dial peer, make sure that audio file is copied to flash.
please collect logs with below debugs if you still face the issue.
debug voip app
Raghavendra
hi please find the debugs, and also while giving the commads it si showing like  enter-pw-prompt flash:enter_pin.au, it is showing namespace is not configured in password2call
From the logs i don't see TCL script is triggered, please make sure you have configured the script under right incoming dial peer.
Raghavendra
Hello, can you please tell me is this solution working or not?
Hi Raghavendra,
I got the same issue. I tried your script and once I inputted the correct password the call was ended and not routed to my MeetMe number.
Is there anything I need to change in your script?
Many thanks,
Jerry
This script actually has nothing to do with MEETME, I would check the following:
1. calling meetme directly without tcl script see if it's working.
2, use this script but just set the destination to a phone see if it's working.
If both are working fine then we need to debug the interworking.
