LUA Script to modify contact header
fgleanza
Dear, I need to make a script to modify the contact header field,
I need to remove the string "+ sip.instance =" <urn: uuid: 832028f41e6258c46e8de1e8dd3d6723360b5c74> "; reg-id = 1"
String before normalizing:
Contact: <sip: 3001@10.0.1.56: 50772>; + sip.instance = "<urn: uuid: 832028f41e6258c46e8de1e8dd3d6723360b5c74>"; reg-id = 1
String after normalizing
Contact: <sip: 3001@10.0.1.56: 50772>; q = 1
Could you help me put the script together?
Thank you very much
17 Replies 17
Jonathan Els
Level 5
Level 5
Can you confirm where you're getting q = 1?
Is that static or dependent on the reg-id value?
Hi Jonathan,
I need to add that value q=1 at the end of the string, is that possible? This value the constant
No problem, give me a few minutes
Excellent, thanks
Last question.. in what messages do you want this applied?
Invite?
Any?
Other?
And in outbound direction or inbound?
Hello,It is possible in the Register?
REGISTER sip:10.57.0.99 SIP/2.0
Via: SIP/2.0/UDP 10.0.1.56:50772;branch=z9hG4bK-524287-1---5987c626fa82397b;rport
Max-Forwards: 70
Contact: <sip:3001@10.0.1.56:50772>;+sip.instance="<urn:uuid:832028f41e6258c46e8de1e8dd3d6723360b5c74>";reg-id=1
should work in a register message... do you want to only apply this to register?
Also, is this inbound to CUCM or outbound?
If only to register, and inbound to CUCM
ok, this should work for you:
M = {}
trace.disable()
function M.inbound_REGISTER(msg)
    local contact = msg:getHeader("Contact")
    if contact
    then
        local qval = "q = 1"
        contact = contact:gsub("(.*<sip:.*>);.*", "%1" .. "; " .. qval)
        trace.format("Found contact header... modifying to: %s", contact)
        msg:modifyHeader ("Contact", contact)
    end
end
return M
looks for contact header, if it finds it, it updates to strip out everything after <sip:.*>, and concatenates "; q = 1"
For  your own knowledge, the relevant API guide for this is here:
Developer Guide for SIP Transparency and Normalization - SIP Messages APIs [Cisco Unified Communications Manager (CallMa…
Thanks, I tried it but the modification was not made.
REGISTER sip: 10.57.0.99 SIP / 2.0
Via: SIP / 2.0 / UDP 10.0.1.106:57477;branch = z9hG4bK-524287-1---f0fbbe4b26111c40;rport
Max-Forwards: 70
Contact: <sip: 3001@10.0.1.106: 57477>; + sip.instance = "<urn: uuid: 832028f41e6258c46e8de1e8dd3d6723360b5c74>"; reg-id = 1
To: "Fernando" <sip: 3001@10.57.0.99>
From: "Fernando" <sip: 3001@10.57.0.99>; tag = ae39740c
Call-ID: 75944M2YyMjNmMzIxMmE5ZTJlYTMzNGUxY2IyYzdiMDhlMDk
CSeq: 1 REGISTER
Expires: 3600
Allow: SUBSCRIBE, NOTIFY, INVITE, ACK, CANCEL, BYE, REFER, INFO, MESSAGE
Supported: outbound, path
User-Agent: X-Lite 4.8.0 75944-8638137a-W6.2
Content-Length: 0
because it can be?
Did you reset the SIP Trunk after applying the lua script??
Please share the SDL file.  also, please enable tracing for the script on CUCM.
Also, just to confirm, you are applying this to a SIP Trunk?  Not sure what your REGISTER flow is through the trunk.
This script is associated with a sip profile that has a third-party device.
Attached the log
This is what I thought.  I'll have a look at the SDL trace to confirm, but I'm pretty sure that what you're trying to do is not supported.  I think the Lua scripts are only available for SIP Trunks.
