Program won't exit (CUCM 10.5)
Greenberet
when I create an application with jtapi, then it will never exit.
I've even created a simple program which just uses the provider, but the program won't exit.
import javax.telephony.*;
public class Startup {
     * @param args
    public static void main(String[] args) {
        // TODO Auto-generated method stub
        try
            JtapiPeer peer = JtapiPeerFactory.getJtapiPeer(null);
            String providerString = "<server>;login=<user>;passwd=<password>;appinfo=BusyLamp";
            Provider provider = peer.getProvider(providerString);
            System.out.format("Started Provider");
            provider.shutdown();
            System.out.format("Provider Shutdown");
        }catch( Exception e)
The main function will return, but the program will never exit.
Am I missing something here or is this a bug?
you gave me the right hint.
I've just disabled logging via
                var properties = peer.getJtapiProperties();
                properties.setUseFileTrace(false);
                properties.setUseJavaConsoleTrace(false);
and now it is working as expected =)
mpotluri
Level 5
Level 5
You may want to try 'System.exit(0);' at the end.
If you have JDK installed, you can run jconsole to check if there are any threads running.
sorry for the late delay, but I was on holiday.
This didn't really work well =(.
I've also tried this with OpenJDK & ikvm (.NET Wrapper)
This is the Callstack with .NET
  • mscorlib.dll!System.Threading.Monitor.Wait(object obj, int millisecondsTimeout, bool exitContext) + 0x16 bytes
  • mscorlib.dll!System.Threading.Monitor.Wait(object obj) + 0xa bytes
  • IKVM.OpenJDK.Core.dll!java.lang.Thread.objectWait() + 0x116 bytes
  • IKVM.OpenJDK.Core.dll!java.lang.Object.instancehelper_wait(object this = {java.lang.Object}) + 0x28 bytes
  • jtapi.dll!com.cisco.cti.util.BlockingQueue.take() + 0x4c2 bytes
  • jtapi.dll!com.cisco.cti.util.MessageThread.run() + 0x31d bytes
  • IKVM.OpenJDK.Core.dll!java.lang.Thread.threadProc2() + 0x47 bytes
  • IKVM.OpenJDK.Core.dll!java.lang.Thread.threadProc() + 0x47 bytes
  • IKVM.OpenJDK.Core.dll!java.lang.Thread$1.Invoke() + 0x23 bytes
  • mscorlib.dll!System.Threading.ThreadHelper.ThreadStart_Context(object state) + 0x6f bytes
  • mscorlib.dll!System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx) + 0xa7 bytes
  • mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx) + 0x16 bytes
  • mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state) + 0x41 bytes
  • mscorlib.dll!System.Threading.ThreadHelper.ThreadStart() + 0x44 bytes
krzys1988
Hi.
I had the same issue. My solution was to disable logger thread.
Try adding jtapi.ini file with following configuration:
UseLogFileTraceWriteThread=0
Hope it helps
