Manual devices configuration - DNAC Audit?
paulo_souza
Level 4
Level 4
Hi guys, does someone know how DNA Center deal with possible direct configuration on devices versus what was configured via DNAC? is any audit report, error or warning for the admnistrator? thanks ins advance.
Pavan Siripuram
This would be part of Compliance feature which we are working on , this is in roadmap and will be available next year.
Dan Rowe
Hey Paulo,
I am a little confused by your query. Are you asking how DNA handles managing devices with pre-existing configuration (brownfield) versus devices which were completely configured / provisioned through the DNA center appliance?
Best Regards,
ChuckMcF
Yes. Short answer is that it’s hit or miss. Change something simple like the hostname and DNAC doesn’t care. Change significant things and it’ll tell you that it isn’t in compliance. Usually that shows up in the main fabric page shortly after you make the change.
what are you looking to change? If you can give me a list of items I can probably tell you if they’ll cause issues.
Chuck
