trying to integrate with HP OVPM to monitor Cisco Rack mount h/w
agilentcompute
We are trying to integrate with HP OVPM to monitor Cisco Rack mount h/w C220’s/C240’s servers but after 48 hrs IMC went to faulted mode.
Cisco IMC Smart Plugin for HP Operations Manager (version 1.0(1))
  • We did the installation from scratch using IMC Smart plugin for HPOM document without missing any steps .
  • Within 48 hrs IMC went to faulted mode .
  • We changed the service account for IMC monitoring service from local system account domain account which is used for HOVPM
Below is the screen shot and also attached HPOM logs
agilentcompute
HI All ,
Here is the actual error in the IMC Logs , Pls review and let us know
May 12, 2016 8:26:15 AM com.cisco.imc.hpom.common.Util logMessage
INFO: Host ::cos-us-dc23-c.cos.agilent.com Keep Alive response:: <aaaKeepAlive cookie="1462947847/c4970b92-328b-128b-804a-4c838322e470" response="yes"> </aaaKeepAlive>
INFO: Host ::cos-us-dc24-c.cos.agilent.com Keep Alive response:: <aaaKeepAlive cookie="1462947847/e08754b8-328b-128b-804a-96675978ac58" response="yes"> </aaaKeepAlive>
May 12, 2016 8:36:13 AM com.cisco.imc.hpom.xmlintegration.Util logMessage
INFO: Resubscribed with id java.io.BufferedReader@16f2b5e7
INFO: UCSEventMonitor:: Loading Faults from UCS  : cos-us-dc24-c.cos.agilent.com
INFO: Host Name ::cos-us-dc24-c.cos.agilent.com fault query ::<configResolveClass cookie="1462947847/e08754b8-328b-128b-804a-96675978ac58" classId="faultInst" inHierarchical="no"/>
May 12, 2016 8:36:14 AM com.cisco.imc.hpom.common.Util logMessage
INFO: Host ::lsplunksh-c.cos.agilent.com Keep Alive query:: <aaaKeepAlive cookie="1462951162/3aefada1-328c-128c-8049-d2b9e18f835c"/>
May 12, 2016 8:36:17 AM com.cisco.imc.hpom.common.Util logMessage
INFO: Host ::lsplunksh-c.cos.agilent.com Keep Alive response:: <aaaKeepAlive cookie="1462951162/3aefada1-328c-128c-8049-d2b9e18f835c" response="yes" errorCode="555" invocationResult="service-unavailable" errorDescr="Session not found"> </aaaKeepAlive>
May 12, 2016 8:36:17 AM com.cisco.imc.hpom.xmlintegration.Util logError
WARNING: Exception Occured in Refresh UCS Task Thread ID : 7070 Name : Timer-1904 Message
Error with keepAlive
May 12, 2016 8:36:17 AM com.cisco.imc.hpom.xmlintegration.Util logMessage
INFO: Stopping Event Monitor : lsplunksh-c.cos.agilent.com
INFO: Host ::lsplunksh-c.cos.agilent.com Unsubscribe Query:: <eventUnsubscribe cookie="1462951162/3aefada1-328c-128c-8049-d2b9e18f835c"/>
May 12, 2016 8:36:18 AM com.cisco.imc.hpom.xmlintegration.Util logMessage
INFO: Host Name ::cos-us-dc24-c.cos.agilent.com fault query response ::<configResolveClass cookie="1462947847/e08754b8-328b-128b-804a-96675978ac58" response="yes" errorCode="552" invocationResult="service-unavailable" errorDescr="Authorization required"> </configResolveClass>
INFO: Done-LoadFaultscos-us-dc24-c.cos.agilent.com
INFO: AppManager :: updateFaultedStatusMap :: Host ::cos-us-dc24-c.cos.agilent.com message ::Monitored fault observed ::false
May 12, 2016 8:36:19 AM com.cisco.imc.hpom.xmlintegration.Util logMessage
INFO: Exception occured sendStatusToAllClients ::Connection refused to host: 130.29.29.91; nested exception is:
    java.net.ConnectException: Connection refused: connect :: cause ::java.net.ConnectException: Connection refused: connect
INFO: Client WCOSOPSMAN1 unregistered successfully
INFO: Client WCOSOPSMAN1 registered Successfully
INFO: Resubscribed with id java.io.BufferedReader@277fbf91
INFO: Error in subscription : null
INFO: Monitoring Stopped for : cos-us-dc23-c.cos.agilent.com
INFO: AppManager :: removeFromEventMonitoredMap ::false
May 12, 2016 8:36:20 AM com.cisco.imc.hpom.xmlintegration.Util logMessage
INFO: AppManager :: updateFaultedStatusMap :: Host ::lsplunksh-c.cos.agilent.com message ::Error with keepAlive fault observed ::true
INFO: Error in parsing Event : XML document structures must start and end within the same entity.
INFO: Event Str ::null
INFO: Event str is null ::3
INFO: UCSEventMonitor :: reSubscribeUCS ::Start
INFO: Trying to close event channel stream with id java.io.BufferedReader@16f2b5e7
INFO: Client WCOSOPSMAN1 already Unregistered
INFO: AppManager :: updateFaultedStatusMap :: Host ::cos-us-dc23-c.cos.agilent.com message ::FaultedError in event subscription null fault observed ::true
May 12, 2016 8:36:21 AM com.cisco.imc.hpom.common.Util logMessage
INFO: Host ::lsplunksh-c.cos.agilent.com Logout Query:: <aaaLogout inCookie="1462951162/3aefada1-328c-128c-8049-d2b9e18f835c"/>
May 12, 2016 8:36:21 AM com.cisco.imc.hpom.xmlintegration.Util logMessage
INFO: com.cisco.imc.hpom.xmlintegration.UCSEventMonitor$1 :: UncaughtExceptionHandler :: Retry Login to Host : lsplunksh-c.cos.agilent.com retry number 0
INFO: Monitoring Stopped for : lsplunksh-c.cos.agilent.com
May 12, 2016 8:36:21 AM com.cisco.imc.hpom.xmlintegration.Util logError
WARNING: Exception Occured in Refresh UCS Task Thread ID : 7073 Name : Timer-1905 Message
null
May 12, 2016 8:36:22 AM com.cisco.imc.hpom.xmlintegration.Util logMessage
INFO: AppManager :: updateFaultedStatusMap :: Host ::lsplunksh-c.cos.agilent.com message ::FaultedError in event subscription null fault observed ::true
May 12, 2016 8:36:23 AM com.cisco.imc.hpom.xmlintegration.Util logMessage
INFO: AppManager :: updateFaultedStatusMap :: Host ::cos-us-dc24-c.cos.agilent.com message ::Monitoring Stopped For Cisco IMC Server. fault observed ::true
Cisco UCS X-Series Energy Efficiency Offer
