05-19-2015 05:08 PM
we are trying to integrate webex data to our salesforce. i have downloaded the schema files. i cant see the custom fields.
how to read the custom field information.
12-09-2015 11:15 AM
Greetings, Prasad! Are you experiencing these difficulties when trying to use Salesforce to import the data, or a WebEx API to export it?
02-03-2016 10:02 PM
Hi Prasad,
It depends on what custom fields you are looking for. Webex supports tracking codes at both the user and the meeting level. These can be returned with GetUser for the user level, or GetMeeting at the meeting/scheduling level. If you need more information on custom fields please reply back with more details on which custom fields you are specifically looking for.
Thank you,
