Cisco EXP-C and EXP-E Issue
ibtihaj2010
Hey mates , need help with vpnless Jabber config using EXP-C/E
My cucm/cups/exp-C are all in Voice VLAN , the exp-E is in DMZ vlan.
I am using 2 NIC option for exp-E , one NIC is in Voice VLAN (where cucm/cups/exp-c are) , second NIC hits the DMZ VLAN
(default gateway for exp-E is targeted towards DMZ gateway)
I will now NAT my Public Static IP to the DMZ VLAN IP on the exp-E so that it can communicate to the outside world.
Please correct if any of the above are incorrect?
Now the second issue is , internal domain in use is  ABCD.BBP.GOV.PK while outside domain is BBP.GOV.PK
Jabber users login thru user@BBP.GOV.PK
Internal DNS resolves as:
CUCM = cucm1.abcd.bbp.gov.pk
cups = cups1.abcd.bbp.gov.pk
exp-c = expc.abcd.bbp.gov.pk
exp-e = expe.abcd.bbp.gov.pk
Now I am really confused what to do with SRV/A-records for internal as well as external clients , this is my first install , please can someone highlight what to do?
Thanks in advance.
Jaime Valencia
