Having Problems Integerating Cisco Jabber SDK
amir.meshkin
I am trying to use the sample file in the jabber sdk, but it won't work. I've downloaded the chrome extension.  I have a page set up with all the necessary js.  But am getting the error below.
Plug-in is not available or has not been initialize
It's not signing in
  1. error:handleSignInFailure(error)
    1. arguments:null
    2. caller:null
    3. length:1
    4. name:"handleSignInFailure"
    5. prototype:Object
Jaime Valencia
SDKs and APIs are supported in DevNet.
java
if this helps, please rate
