Jabber 12.7 and Mac os Catalina Attach file problem
c-ascione
Level 4
Level 4
I am using Jabber Version 12.7.0 (288631) on Mac Book pro and after Mac OS upgrade to Catalina ( 10.15 ) the option attach ( send file) doesn't work anymore.
Has someone the same problem ? Or if  I need to change some configuration on the Mac ?
gausaxen
I am running Jabber 12.6.0 (281201) and even after upgrading to MacOS Catalina the file attach functionality works fine.
gausaxen
Probably in your case Jabber does not have access to various folders and hence is not able to attach files from them
