02-03-2015 07:59 AM - edited 03-17-2019 04:51 PM
Jabber for Android was working perfectly on my Nexus 6 with Android L 5.0, why has the public release dropped this phone? I went through the BETA program using this device, it is way more reliable than Jabber on my Samsung S5.
Solved! Go to Solution.
02-05-2015 08:31 AM
Hey, the 10.6 APK available on Cisco.com downloads can be installed on the Nexus 6 outside of the Google Play Store. Annoying yes, but at least I have Jabber installed again. :)
02-03-2015 01:22 PM
Cisco Development team does rigorous testing with the phone models, and it is not possible to test with all models.
However, with 10.6 we are officially supporting a lot more phone models than the previous versions of Jabber client.
02-03-2015 01:27 PM
Thanks for the reply. In the google Play store, my Nexus 6 is listed as unsupported, so the download is no longer available. Can this be fixed?
02-03-2015 01:33 PM
Ohh that is unfortunate.
Could you share the exact version of Android installed on ur phone, kernel version, and a screen shot of the error?
I will follow this up
02-04-2015 06:38 AM
02-05-2015 08:31 AM
02-05-2015 08:51 AM
Thanks, I've done that now. Hope they can get the Play store sorted out soon, side loading is not optimal for an enterprise deployment.
02-05-2015 08:54 AM
Agreed, I'm hoping this issue doesn't extend to other Android L devices.
02-05-2015 09:24 AM
I'm following up on this. Looking forward to get this sorted out.
02-12-2015 07:20 AM
Good Morning Nirmal, Any updates available on this issue?
03-16-2015 01:38 AM
Hi Walshliam,
I'm sorry for the delay in response. IThe upcoming version J4A 10.6.1 will support nexus 6
Nirmal Issac
02-11-2016 09:34 AM
I bought a Nexus 6P and it's not working! I'm the Collaboration Engineer for my CO and Jabber Mobile is not working on my phone. Google Play says not supported!!!
02-18-2016 03:06 PM
it seems it has been taken off due to a bug i expected it to be available soon.please see below
https://help.webex.com/docs/DOC-4903
https://code.google.com/p/android/issues/detail?id=197579
04-15-2016 02:13 AM
Hi ,
I am facing the same issue with Jabber on Nexus 6P. Will this be fixed anytime soon? I see this issue has persisted for quite some time.
02-19-2015 11:09 AM
Good Afternoon Nirmal, Any updates available on this issue?
