Jabber Installation Guide
zohaib.shabir
Hi All,
Recently we have received a license file from cisco as one of our customer has requested the Jabber for thier working enviorment.They will use jabber for thier windows based desktop clients, for android phone, iPhones, iPad and Blackberry.
Customer has CUP 8.0 with CUCM 8.0 enviorment with no active directory.
cisco has sent the below license files.
Product                          Description Entitlement              Qty
CUP-86-K9-SW-PAK     CUP 8.6 SW Kit & PAK                1
JABBER-IM-RTU           Jabber for Everyone Right to Use   1
it contains the 1200 user licenses.
i have searched alot but fail to find any document from cisco which describes that where do i put this license either on CUP or CUCM.
pls help me to understand that:
where should i add the license file ?
is there any configuration required on CUP ?
is there any configuration required on CUCM ?
how do i configure it on blackberry ?
if there any Video link is availble which describes these steps or any document then pls share.
your reponse will be highly appriciated.
Jaime Valencia
CUCM
Yes
Yes
You only enable the user for CUPS/CUPC on CUCM once you've done all the basic config for CUCM user/device/line
Cisco Jabber for Windows 9.0.x Administration Guide
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/jabber/Windows/9_0_1/b_jabber_win_icg.html
ALL the jabber guides are available on CCO, just search "Jabber for " and you'll get the guides for each version.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
what about below license file ?
i did not found any PAK key in the document where it shows this:
