07-04-2017 11:19 PM - last edited on 03-25-2019 08:57 PM by ciscomoderator
Hi there
I just wonder if I can seek your advise about a minor issue we got when we try to join webex from a computer
attach is example of one of the webex meeting invitation in outlook invitation and user just click onto Click here to join from computer
The IE then loading and keep prompting for username/password before the actual Webex plug in can open the loading webex meeting
We did select remember username/password and it keep prompting again which create annoying for user as we have been told once we select remember the log in it should not prompt the credential
I just wonder if you have any idea of fixing this issue?
07-07-2017 03:46 PM
Martin,
I recommend you contact WebEx Support for this case so the technical support experts can help find a solution to your particular problem.
Support Tools and Resources | WebEx
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
07-10-2017 01:22 PM
Check the entries in your browser for automatically saving passwords. I found that I would have my personal password saved, but when I attempted to join a meeting that required the password it would populate my personal password. Would have to go and get the session password. Key is to make sure and not click the button to update the password. That would then replace your current password with the individual session password. Might help you out. Thanks.
