06-16-2015 07:38 AM - edited 03-17-2019 05:16 PM
Dears,
We have scenario of One CUCM CLuster & One IM & P Cluster at Site 1 and another CUCM and IM P CLsuter at Site 2.
All 4 clusters are served by a single AD domain but users at each site are grouped in the AD Security Group & sync with relevant cluster.
We want to deploy MRA using Expressway at Each site. We wanted to connect users at Site 1 to use expressway at Site 1 & users at Site 2 to expressway at Site 2.
Can you please help how can we achieve the design using single email address domain,
Thanks in Advance.
Thomas
06-16-2015 03:52 PM
somewhere this is gonna bite you in the back, but anyway you must have your reasons for wanting this.
Set it up as you suggest two expressway/control clusters, each pointing to their own CUCM cluster.
on your VCS control each will then have a pattern:
(.*)@yourcompany.com(.*)
pointing to their respective cucm clusters (so site 1 VCS > Site 1 CUCM etc.), so far so good.
I think for the communications bewteeen the two CUCM cluster, you will need to have a look at ILS:
https://supportforums.cisco.com/document/12243806/chalk-talk-sip-uri-dialing-and-ils-networking
06-17-2015 06:58 AM
Dear Dennis,
Thanks for your quick response and suggestion. I am still confused.
Consider I have expressway-edge-site1 & expressway-edge-site2 are located in Site 1 & Site2 respectively. So I need to use two public IP, one at each site. I have to create the srv record collab-edge with mapping to two public IPs and available in the external dns at both sites.
Consider I have user1@mydomain.com is located in Site1 & user2@mydomain.com is located in Site 2. So basically collab-edge srv will resolve this address can be either of the Expressway.
So for example - when user1 is Site 1 try to log-in , there is always a chance that srv record might resolve to Site 2 expressway public IP instead of Site 1 expressway IP.
Is there any mechanism that user1 will always resolves to Site 1 expressway public IP ?
Thomas
