02-04-2020 07:11 AM
This just came out yesterday so this is more directed for anyone lurking at Cisco, but how is this supposed to work?
Our UM has been disabled for months because of MS security requirements for resellers that broke the old way so I quickly installed this in my test lab to see if it will fix my issue.
According to all the MS documentation there should be no need to use the old Autodiscover, etc that Unity was using. You just connect to the default outlook.office365.com EWS url and use your oauth info and boom. The whole point is to not have to setup an account with special permissions, etc.
However, the fields for the old account are still there and mandatory and all the test options are going through and failing Autodiscover…
If I look at the Mailbox Sync Logs I don’t see any evidence it’s trying to use Oauth/EWS.
Anyone in the know out there?
04-10-2024 10:46 AM
My customer is planning to migrate from EWS to Microsoft Graph.
We need to know if there is anything from Cisco Unified perspective that we need to be aware of or update.
Is there any Cisco guide for Cisco UCxn to work with and Microsoft Graph
Thank you
04-10-2024 11:06 AM
From what I know CUC version 14 SU3 and onwards uses Graph instead of EWS.
