SX80 integration with third-party control systems on Spark
adrien.gallais
I will migrate a customer SX80 from On premise to Cisco Spark registration. The SX80 is connected to a Crestron with some AV integration (Projector, microphones, speakers, etc...)
I see on the link below : https://help.webex.com/docs/DOC-18239
It's mentioned: The web interface and API that are available for Cisco Spark registered room devices are scaled down compared to what is available for on-premise registered devices. Once you are signed in to the web interface, you can see the full list of available configurations and status information.
and at the end : Note that only a subset of the features described in these guides is available for Cisco Spark registered room devices
Does anyone know the list of the exact API commands that are available for an SX80 running Spark Room OS ?
thanks
keglass
Level 7
Level 7
Adrien,
I recommend you contact the Cisco Spark for Developers support team for more information. See below for help and additional resources.
https://developer.ciscospark.com/support.html
Thank you for participating in the Community.
Kelli Glass
Moderator for Cisco Customer Communities
keglass
Level 7
Level 7
Adrien,
Kelli Glass
OK thanks Kelli I will write to the developpers
