Undeleteable meeting after using @webex location
khoult
I created a meeting using the @webex in the location option. Now the meeting can't be accessed/deleted by anything and touching it causes the following error:
"Sorry, we're having trouble opening this item. This could be temporary, but if you see it again you might want to restart Outlook. An error occurred in the underlying security system. An internal error occured."
No amount of restarting outlook helps. I'm unable to make any change to the meeting. It breaks my meeting sync tool with my phone since it's unreadable.
Anyone else had this problem and found a way to fix it?
Thanks, Kent
Chad Patterson
Hey Kent,
Sorry to hear you are having this issue. I would recommend you open a support case to allow us to look into this with you. Let me know if you need help getting a support case opened!
Chad
Hi Chad,
I did open case 62204 at Cisco Spark | Help
Is that the right place?
Thanks, Kent
