03-06-2018 10:48 AM
As I already post the problem in the support forum, I will just let the URL here and hope that you can help me.
Bulk Transcript Downloader Error - Cisco Support Community
Thanks in advance.
Solved! Go to Solution.
03-07-2018 12:55 PM
Hi Martin,
I have provided the answer to your original query in supportforums.cisco.com.
I'm also adding it below.
Hope this helps.
Oops, but good catch!
Basically, the bulk transcript downloader script is unable to process unicode (UTF-8 encoded) characters. (Do your transcripts have multi-byte, non-english characters in them?)
It is a simple fix, I will do it and re-publish this code.
Meanwhile, can you try one of these options?
FYI, all the sample code of SocialMiner (including this one) is available publicly on github.com now!
Check out https://github.com/CiscoDevNet/socialminer-sample-code
03-07-2018 12:55 PM
Hi Martin,
Hope this helps.
