Need help with CVP->ICM media files
alexporter92
Currently our media files are set to the default "app". in the ICM script I am specifying what .wav file I need on the media server by using "FOLDERNAME/prompt01.wav".  What I would like to do is define this in the script on ICM. This way I only need to define the folder name 1 time and ICM will look for WAV files in the specified folder.
Any file in our defualt "app" on CVP will play the specified file. What I did is create a folder underneath "app" app/Foldername/wavfile.
All I want to do is define the FOLDERNAME one time on the ICM script, this way if the folder name changes, all I have to do is change it in one location.
Running ICM 10.5.2
16 Replies 16
Have you tried adding that folder in the media library variable (user.app_media.lib)?
alexporter92
"application=PlayAudio;audio=DSSSNAP8051/prompt0003.wav"  To sum up, this is where are media files are defined in CVP. App/DSSSNAP8051 and the ICM script reflects it. Instead of adding this logic to every media file, cant I just define this location one in ICM before I start in with the media files?
