Cisco Nexus 7k password recovery for admin vdc and non-default vdc
Dear All,
Good day,
I have cisco Nexus 7000 series switches with VPC configured. I have 3 VDC configured in each nexus switch and the password for 2 VDC in 1 switch and 3 VDC in another switch includes admin VDC password not working. I have to reset the password for both switches. Kindly advise how I can do it. Should I need to ask for downtime to the company?
Kindly advise and please put the steps that I need to follow because I am going to do in production environment.
Thanks and Regards,
Kabeer
Francesco Molino
If you don't have anymore the password then you're going to need to reboot the box:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/password_recovery/b_nx_os_pwr/nx_os_pw.html
This means it'll be disruptive for the production.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hi All,
I got the downtime from the company, So I need to recover the password for all VDC.
I prepare my own document, could you please verify it
Steps to follow to reset the password for Nexus Switch
In the below steps, I am not able to understand why we need to do step 8 ?
and after I reset Admin VDC password how can i switch to other VDC to recover the password?
  1. Connect the console to the switch
  2. Reboot the switch
  3. While rebooting continuously press ctrl + C or ctrl +] to break the bootup
  4. And then switch will enter the below mode
Here if it shows loader we need to enter below command
Loader> boot kickstart.x.x.x.x.bin
And then it will enter boot mode
switch(boot)# configure terminal
switch(boot-config)# admin-password <new password>
WARNING! Remote Authentication for login through console has been
disabled
switch(boot-config)# exit
switch(boot)#
   5.then look at the directory file           dir bootflash:
  1. Load the Cisco NX-OS system software image.
In the following example, the system image filename is nx-os.bin:
switch(boot) # load bootflash:nx-os.bin
  1. Log in to the device using the new administrator password.
switch login: adminPassword: <new password
  1. Reset the new password to ensure that is it is also the Simple Network Management Protocol (SNMP) password.
switch# configure terminalswitch(config)# username admin password <new password>switch(config)# exit9. and then save the configuration switch# copy running-config startup-config
