Transport:
Type: CSLU
Cslu address: https://10.50.0.xxx/cslu/v1/pi/xxxxx-1
sho license certs
Production Cert: True
PIID: <empty>
Licensing Certificated:
Root Cert Info:
Start Date: May 30 19:48:47 2013 UTC
Expiry Date: May 30 19:48:47 2038 UTC
Version Number: 3
Serial Number: 1
Common Name: Cisco Licensing Root CA
2023-06-12 08:39:01.282 CET SAEVT_COMM_FAIL error="Cannot establish secure connection because server
TLS cert cannot be validated"
2023-06-12 08:39:11.225 CET SAEVT_UTILITY_REPORT_START
2023-06-12 08:39:11.270 CET SAEVT_COMM_FAIL error="Cannot establish secure connection because server
I am getting above error, If I am trying to connect my NXOS with On-Prem License server. I know we have a fix in cat switches as:
* (config)#crypto pki trustpoint SLA-TrustPoint
(ca-trustpoint)# revocation-check none
Do you know any command for Nexus NX-OS 10.3(2) or have to import on-prem certificate etc?
Note: the rootCA used by the onPrem (or some intermediates) is not installed on NX switch
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
