Error when adding VLAN to Uplink
pz
I am getting an error when trying to add a VLAN to one of my Uplink profiles. I have 2 uplink profiles and one worked fine, but the other will not add the VLAN.
Here is the output:
7i27i2(config)# port-profile type ethernet Uplink-Communication
7i27i2(config-port-prof)# switchport trunk allowed vlan add 434
ERROR: The vlan(s) being configured does not contain some or all of the configured system vlans
Here is the complete port profile:
  vmware port-group
  switchport mode trunk
  switchport trunk native vlan 400
  switchport trunk allowed vlan 200-203,400,460-461,483,489,500,586,702,715,720-
721,740,800,1220
  channel-group auto mode on mac-pinning
  no shutdown
  system vlan 200-203
  state enabled
I am running 4.2(1)SV2(4).
i cannot figure out how to fix the issue.
It looks like the issue is due to interface overrides on the port-channel interfaces. Can you try executing "default switchport trunk allowed vlan" on each port-channel interface? This command will make the port-channel interface config consistent with the port-profile it is inheriting. Afterward, you can try the "switchport trunk allowed vlan add" command on the port-profile and it should go through successfully
Sean
5 Replies 5
pz
Typed the version incorrect.
4.2(1)SV1(4).
Can you attach the output of "debug port-profile all" and "debug vlan all" while executing "switchport trunk allowed vlan add 434"? You can do something like this:
7i27i2(config-port-prof)# debug port-profile all
7i27i2(config-port-prof)# debug vlan all
7i27i2(config-port-prof)# debug logfile ppm-vlan
7i27i2(config-port-prof)# no debug all
7i27i2(config-port-prof)# copy log:ppm-vlan scp://
Also, if you could grab the output of "show tech-support svs", that would be helpful as well.
As for a workaround, have you tried entering the full vlan list on the port-profile that includes the new vlan? Something like this:
  switchport trunk allowed vlan 200-203,400,434,460-461,483,489,500,586,702,715,720-721,740,800,1220
Sean
Hi Sean,
Thanks for the reply.
I have attached the files you have requested.
I also tried to do the workaround and got the same error message:
min7i2(config)# port-profile type ethernet Uplink-Communication
min7i2(config-port-prof)# switchport trunk allowed vlan 200-203,400,434,460-461,483,485,489,500,586,702,715,720-722,740,800,1220
Thanks for your help.
Sean
Thanks Sean. That worked.
After starting to read some of this Community stuff, I found that you were not suppose to add stuff to the port channels...just let them inherit. But I had already done it and had yet to find the command to reverse.
Thanks for all your help!
