Multi-NIC vMotion with 1000v and UCS
workman.matt
I have a question regarding multi-nic vMotion and the Nexus 1000v. I know how this would be configured using standard or regular distributed switch in vCenter. I would create a two vMotion vmkernel ports and make vmnicX active and vmnicY standby and vice versa for the other vMotion port.
How does multi-nic vMotion work with the 1000v with Cisco UCS in mind? Our hosts have 2 vNICs (1 on each side of the fabric).
lwatta
Shouldn't be a difference. You would simply use pinning to make sure vmnicX goes up link 0 and vmnicY goes up link 1.
So on the N1KV you would create an uplink port-profile that does VPC mac pinning
port-profile type ethernet Uplink-PP
switchport mode trunk
switchport trunk allowed vlan all
no shut
vmware port-group
channel-group auto mode on mac-pinning
state enable
Then create two port-profiles for your vmnics
port-profile type veth vmnicX
switchport mode access
switchport access vlan X
no shut
vmware port-group
pinning-id 0
state enabled
port-profile type veth vmnicY
switchport access vlan Y
no shut
vmware port-group
pinning-id 1
state enabled
That's it. I would read up on VPC MAC-Pinning port-channels, but it's pretty easy.
louis
Our hosts have two NICs for all traffic.So access mode for them would not work. Also, both vMotion ports would use the same VLAN.
The eth uplink port is a trunk so that shoud work for you unless I am misunderstanding the issue.
For the veth port-profiles you can create two port-profiles with the same vlan. That's fine. The key is to make sure each port-profile pins to a different uplink. Then when you assign vnicx to port-profile-X you know that traffic is only going up that link.
Hope that helps
louis
