NETFLOW ON N5K vPC
motas
I want to configure netflow on N5K in two switches in vPC, follow the config:
feature netflow
flow record record_nf
match ipv4 source address
match ipv4 destination address
match transport source-port
match transport destination-port
collect counter bytes
collect counter packets
flow exporter exporter_nf
destination 10.0.1.254
source mgmt
transport udp 2055
version 9
flow monitor monitor_nf
record record_nf
cache timeout active 60
interface eth1/9
ip flow monitor monitor_nf input
In my example, i'm applyng on only one interface, but the environment has the need of exporter the traffic of all interfaces for remote collector, is this possible?
Applying on all interface has any impact for environment?
2 Accepted Solutions
anpetit
Hello @motas ,
Hope you are doing well.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5600/sw/system_management/7x/b_5600_System_Mgmt_Config_7x/m_6k_configuring_netflow.html
This guide is about Nexus 5600, in the section - Guidelines and Limitations for Netflow:
- The maximum number of supported NetFlow entries is 512,000.
- We recommend that you configure NetFlow on a maximum of 500 destination nodes. Each interface and module on which a particular VLAN is active is counted for the NetFlow scale. An example of a NetFlow scale scenario is as follows
- If ingress SVI is configured on a VLAN that is active on 3 interfaces in a single module, the NetFlow scale is 3.
Hope it helps.
Kind Regards,
anpetit
Hi @motas ,
Yes this should be the case following: Each interface and module on which a particular VLAN is active is counted for the NetFlow scale.
Hope it helps.
Have a nice day.
Kind Regards,
anpetit
Hello @motas ,
Hope it helps.
Kind Regards,
Hi @anpetit
Thank you for anwser, so for example, if i configure on twenty interfaces and these interfaces has ten vlans on each, netflow total scale is 200 ?
Best Regards,
anpetit
Hi @motas ,
Hope it helps.
Have a nice day.
Kind Regards,
Hi @anpetit
Thank you for help.
