10-02-2013 03:29 AM
could you help me with a problem -
I configured uplink port-profile but don't have a connectivity through native vlan 1.
If I configure native vlan as vlan 200 in uplink port-profile as example I have a connectivity to my VM located in vlan 1.
But If vlan 1 is configured as native vlan then my VM are not accessible.
Could you give me the way to dig, please?
10-03-2013 08:37 AM
Can you post your uplink port config as well as the config for the switch port it connects to?
I suspect you have a mismatch in the configs.
10-03-2013 08:38 AM
Can you post your uplink port config as well as the config for the switch port it connects to? There is probably a mismatch.
10-03-2013 06:07 PM
I have mgmt int with ip 10.40.1.221 in vlan 1 and control and packet interfaces in vlan 3.
port-profile system_uplink
type: Ethernet
description:
status: enabled
max-ports: 32
min-ports: 1
inherit:
config attributes:
switchport mode trunk
switchport trunk allowed vlan 1-3967,4048-4093
no shutdown
evaluated config attributes:
no shutdown
assigned interfaces:
Ethernet3/1
port-group: system_uplink
system vlans: 1,3
capability l3control: no
capability iscsi-multipath: no
capability vxlan: no
capability l3-vservice: no
port-profile role: none
port-binding: static
interface TenGigabitEthernet3/0/2
