07-27-2023 08:42 AM
I want to configure SSM IP-Range on a Nexus 7700 running 8.4(7)
According to https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus7000/sw/multicast/config/cisco_nexus7000_multicast_routing_config_guide_8x/m_configuring_pim_and_pim6.html the command is
ipv6 pim ssm range FF30::0/96
But the command is unknown to the switch:
cores101(config)# ipv6 pim ?
allow-rp Sparse-Mode RP addresses to be allowed
anycast-rp Configure an RP in an Anycast-RP set (using PIM6)
bidir-rp-limit Configures maximum Bidir RPs for IPv6 PIM in this VRF
bsr Bootstrap protocol RP-distribution configuration
bsr-candidate Configure router as a Bootstrap Router candidate
event-history Configure event-history buffer
flush-routes Remove routes when restarting PIM6
isolate Isolate this router from IPV6 PIM perspective
log-neighbor-changes Log up/down PIM6 neighbor transitions
register-policy Specify policy for receiving Register messages
register-rate-limit Rate limit for PIM data registers
rp-address Configure static RP for group range
rp-candidate Configure router as a Rendezvous Point (RP) candidate
spt-threshold Source-tree switching threshold
state-limit Configures State limit
use-shared-tree-only Use (*,G) only state, no source state is created
feature pim
feature pim6
is enabled.
Any hint how to set the SSM range?
Andreas
07-27-2023 09:54 AM
Hi @ANDREAS LIEBE ,
I am not to sure why this command is missing from 8.4(7). That being said, you can still use SSM with the default range. It is normally recommended to use the default range by the way.
switch# sh ipv6 pim group-range
PIM Group-Range Configuration for VRF "default"
Group-range Action Mode RP-address
Shared-tree-range Origin
ff32::/32 Accept SSM -
- Local
ff33::/32 Accept SSM -
- Local
ff34::/32 Accept SSM -
- Local
ff35::/32 Accept SSM -
- Local
ff36::/32 Accept SSM -
- Local
ff37::/32 Accept SSM -
- Local
ff38::/32 Accept SSM -
- Local
ff39::/32 Accept SSM -
- Local
ff3a::/32 Accept SSM -
- Local
ff3b::/32 Accept SSM -
- Local
ff3c::/32 Accept SSM -
- Local
ff3d::/32 Accept SSM -
- Local
ff3e::/32 Accept SSM -
- Local
07-28-2023 12:33 AM
Harold,
thank you for your quick response!
You're right, we should stick to the standard (e.g. rfc7346)
I became aware of the missing command when I noticed slightly different SSM defaults on NX-OS(ff32::/32) and IOS-XE (FF3F::/32) and looked for a way to align the configs:
nx-os# show ipv6 pim group-range
PIM6 Group-Range Configuration for VRF "default"
Group-range Mode RP-address Shared-tree-only range
ff32::/32 SSM - -
ff33::/32 SSM - -
ff34::/32 SSM - -
ff35::/32 SSM - -
ff36::/32 SSM - -
ff37::/32 SSM - -
ff38::/32 SSM - -
ff39::/32 SSM - -
ff3a::/32 SSM - -
ff3b::/32 SSM - -
ff3c::/32 SSM - -
ff3d::/32 SSM - -
ff3e::/32 SSM - -
IOS-XE#show ipv6 pim range-list
Static SSM Exp: never Learnt from : ::
FF33::/32 Up: 3d02h
FF34::/32 Up: 3d02h
FF35::/32 Up: 3d02h
FF36::/32 Up: 3d02h
FF37::/32 Up: 3d02h
FF38::/32 Up: 3d02h
FF39::/32 Up: 3d02h
FF3A::/32 Up: 3d02h
FF3B::/32 Up: 3d02h
FF3C::/32 Up: 3d02h
FF3D::/32 Up: 3d02h
FF3E::/32 Up: 3d02h
FF3F::/32 Up: 3d02h
