spine switches
bluesea2010
Level 5
Level 5
What are the criteria for choosing spine and leaf switches
Sergiu.Daniluk
The most common criteria:
  • port type (SFP/QSFP/BASE-T)
  • port density
  • bandwidth/throughput
  • supported features (example macsec/cloudsec)
  • generation (FX vs FX2 vs FX3) - this usually goes hand-in-hand with supported features
Stay safe,
Sergiu
emre
hi,
i think capacity .!
So, how many spines and how many leaves will you use?
example: 4 spine and 300 leaves ?
The kitlist is prepared according to the capacity.
port speeds have to be standard min 100gbit ,
most importantly, a redundant design,
