06-03-2021 10:20 AM
I am trying to upgrade Nexus 93180YC-EX to EPLD 9.3.7.
In impact testing it shows that IO FPGA will be upgraded, however, after upgrade when i check this it wouldn't show as upgraded.
(Following output is from 2nd try)
SWH01# install epld bootflash:n9000-epld.9.3.7.img module all
Compatibility check:
Module Type Upgradable Impact Reason
1 SUP Yes disruptive Module Upgradable
Retrieving EPLD versions... Please wait.
Images will be upgraded according to following table:
Module Type EPLD Running-Version New-Version Upg-Required
1 SUP MI FPGA 0x04 0x04 No
1 SUP IO FPGA 0x03 0x15 Yes
The above modules require upgrade.
The switch will be reloaded at the end of the upgrade
Do you want to continue (y/n) ? [n] y
Proceeding to upgrade Modules.
Starting Module 1 EPLD Upgrade
Module 1 : IO FPGA [Programming] : 100.00% ( 64 of 64 sectors)
Module 1 EPLD upgrade is successful.
Module Type Upgrade-Result
1 SUP Success
EPLDs upgraded.
Reseting Active SUP (Module 1) FPGAs. Please wait...
Following a reboot, when i check the epld, it shows me this:
SWH01# sh version module 1 epld
EPLD Device Version
MI FPGA 0x4
IO FPGA 0x3
IO should be 0x15.
I have read about upgrading the EPLD with golden image, However, it does not give option for this.
Not sure what I am doing wrong here.
I would really appreciate any help in this please
06-14-2021 06:46 PM
Hi D.Zeb,
The 'golden' could be hidden or won't show up when you tab or "?".
Can you try to enter the command below:
install epld bootflash:n9000-epld.9.3.7.img module all golden
06-18-2021 07:38 AM
This particular update requires both the primary and secondary images to be upgraded. It's a security vulnerability fix.
The documentation is here:
As seen at the bottom of the page, the way to upgrade to golden. Must upgrade secondary first, reboot, and then upgrade golden and reboot again and it will be fixed.
