Problems with RTU license on WLC AIR-CT7510-K9
Helo everybody,
I´ve seen one problem with RTU license on WLC AIR-CT7510-K9.
With RTU license I have not to install a .lic file to Add a license so, the porblem is when I Add a license and do the accept in EULA the license status is :
But after 24 hours the license desappears in the software activation tab, I tryed to find somthig to explane this problem but there isn´t.
Someone have seen this situation ?
Geevarghese Cheria
Hi Chrystiano,
   Apologies for the delay in responding to you. While searching came across this url which could help to answer your question.
Wireless Access Point Right To Use (RTU) Licensing for Cisco 8500 and Flex7500 Wireless LAN Controllers - Cisco
Thanks and Regards,
Geevarghese
