[DevNet] Errors setting up the sandbox for POAP with NX-OS
jay..
I'm trying to reserve a sandbox (https://devnetsandbox.cisco.com/RM/Diagram/Index/1e9b57ff-9e64-4c68-93e5-f0f0a8c6f22c?diagramType=Topology) using the "POAP" option and it fails everytime (I tryed 3 times) during the setup process resulting in an "Active (with errors)" state.
I can't try to troubleshoot directly on the servers since the e-mail with the credentials is never sent.
The error explicitly wrote :  "Errors occurred preparing systems. Please use the forum at
https://communities.cisco.com/community/developer/sandbox for assistance"
Interestingly enough, without the "POAP" option, the reservation process works perfectly.
Some more informations about the errors :
It looks like the "VIRL Server.NXOSV-003'" is the one failing :
First error :
Second error :
Full feed just before & after the first error :
Did I do something wrong ?
Is there a way to by-pass those errors ?
Thanks in advance !
jacoadam
Level 5
Level 5
Hello Jean-Pierre,
Thanks for reaching out. It doesn't look like you're doing anything wrong. I will check on this lab and see what's going on and get back to you!
Also, you can post questions directly on our forum at https://communities.cisco.com/community/developer/sandbox
Thanks!
Jacob
jacoadam
Level 5
Level 5
Hello Jean-Pierre,
We will be working on this issue this between this week and next. I will update you once this issue has been resolved.
Thanks!
Jacob
