Meraki Enterprise and Small Business Labs fail at reservation
i tried to get a reservation of this Labs.
Unfortunately these two errors appear at the Setup Process after the reservation:
Error: Script runner exited with exit code: 1
Description: Setting up Meraki Instance
Username: Patrick.Urlberger@sws.de
Email: Patrick.Urlberger@sws.de
GET calling: https://api.meraki.com/api/v0/organizations/549236/networks
https://api.meraki.com/api/v0/organizations/549236/networks called successfully
GET calling: https://api.meraki.com/api/v0/organizations/549236/admins
https://api.meraki.com/api/v0/organizations/549236/admins called successfully
No meraki networks available
Parameters:
Error: Resource Command Error
Description: Meraki Python Script Failed
Parameters:
The Lab is then Active(with error) and i don't get an e-Mail with the CiscoAnyConnect Credentials to connect.
Screenshots of the broken Lab are attached here.
zowu
Hi Partrick,
We've fixed Meraki Small Business sandbox, please go ahead to book it again.
Regarding Meraki Enterprise, it is still in maintenance. Our evangelist is helping us to fix it.
9 Replies 9
nfitelop
I'm also experiencing the same issue with both labs.
zowu
Hi Partrick,
zowu
Meraki Enterprise sandbox is also back to catalog.
nfitelop
Thanks for the fast response!
I am new to Cisco, sorry for any inconveniences I might cause.
However this issue is again a problem and the accepted answer should not be a solution anymore.
Or should i just open a new issue request instead? See attachement
Kind regards
Sorry for your inconvenience. And we've just fixed the Meraki sandbox.
Working again. Thank you very much.
SK_66865
Today wanted to setup the Meraki Small Business Lab and got this error as well, so seems to be an issue again see output:
08:36:45 Environment Driver Setup has begun
Setting up Meraki InstaceUsername: <USERNAME_HIDDEN>
Email: <EMAIL_HIDDEN> 08:37:15
Meraki Setup has Failed.
Please contact support at https://communities.cisco.com/community/developer/sandbox
08:37:18 Driver Complete.
setup_meraki' resource command on 'Meraki-001' failed with 'Script runner exited with exit code: 1' error
Error: Script runner exited with exit code: 1 Description: https://api.meraki.com/api/v0/organizations/549236/networks GET calling: https://api.meraki.com/api/v0/organizations/549236/networks https://api.meraki.com/api/v0/organizations/549236/networks called successfully GET calling: https://api.meraki.com/api/v0/organizations/549236/admins https://api.meraki.com/api/v0/organizations/549236/admins called successfully No meraki networks available Parameters:
David Pendleton
I'm working through Chapter 8 in the book DEVASC 200-901. The Meraki sandbox returns 404 for the URL and API key listed in the book pages 184,185: https://api.meraki.com/api/v0/organizations. This seems to be the same problems listed earlier in this thread.
