Anyone have example docker package.yaml with depends-on: ?
Levi Iiams
I'm trying to get IOxCore running so that I can play with that API.  (I am looking for a way to get platform info from my app - like platform serial number for example.  Sorry for adding a second question!)
I'm having trouble with ioxclient yaml validation - it's failing.    Here is what I've got, please help!
I'm running:
ioxclient docker pkg -m -a <imagename:1.0> .
Here is the package.yaml I'm trying to merge - I want to add the 'depends-on' as referenced here: https://developer.cisco.com/docs/iox/#!cisco-core-services/core-services-on-ir8xx-platforms
li-mbp:app_package levi$ cat package.yaml
descriptor-schema-version: "2.2"
info:
  version: "1.2"
app:
  cpuarch: x86_64
  env:
    PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
  resources:
    cpu: "50"
    disk: "2"
    memory: "64"
    network:
    - interface-name: eth0
      ports: {}
    profile: custom
  startup:
    rootfs: rootfs.tar
    target:
    - /bin/sh
    - -c
    - /usr/bin/web-relay.py
  type: docker
  depends-on:
    packages:
      - name: "IOxCore"
        version: "1.5.0"
I'm getting this error:
File /var/folders/42/f8sn5v5d6l3144d4q8d7j4fm0000gn/T/desc739397925 is invalid under schema version 2.2. Errors below:
- app: Must validate one and only one schema (oneOf)
"cpuarch": "x86_64",
"depends-on": {
  "packages": [
    "name": "IOxCore",
    "version": "1.5.0"
"env": {
  "PATH": "/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin"
"resources": {
  "cpu": "50",
  "disk": "2",
  "memory": "64",
  "network": [
    "interface-name": "eth0",
    "ports": {}
  "profile": "custom"
"startup": {
  "rootfs": "rootfs.tar",
  "target": [
   "/bin/sh",
   "-c",
   "/usr/bin/web-relay.py"
"type": "docker"
- app.type: app.type must be one of the following: "vm"
"docker"
- app.startup: Must validate one and only one schema (oneOf)
"target": [
  "/bin/sh",
  "-c",
- kernel: kernel is required
"target": [
  "/bin/sh",
  "-c",
- target: Additional property target is not allowed
"target": [
  "/bin/sh",
  "-c",
- app.depends-on: Must validate one and only one schema (oneOf)
"packages": [
   "name": "IOxCore",
   "version": "1.5.0"
- services: services is required
"packages": [
   "name": "IOxCore",
   "version": "1.5.0"
I've looked around, I can't find a good reference yaml file that has this requirement.
Levi Iiams
Oh ok small update - I misunderstood the interplay between 'apps' and 'services'.
I think I'm going down the wrong rabbit hole.
