IOx docker application package signing
smulye
Hello
I want to sign my docker application package that I am hosing on a Catalyst 9300. I am following the steps from this guide:
https://www.cisco.com/c/en/us/support/docs/cloud-systems-management/iox/212472-configure-iox-package-signature-validati.html
I have generated a trust anchor tarball but when I try to import it on my 9300 device using ioxclient tool, I get this error:
 #./ioxclient platform signedpackages trustanchor set trustanchorv1.tar.gz
Currently active profile :  default
Command Name:  plt-sign-pkg-ta-set
Cannot unmarshal response from server to JSON. Malformed response.
Error occurred :  Trust anchor management is not enabled on this platform.
How do I fix this issue? Am I missing any configuration to enable "Trust anchor management"?
Any help would be much appreciated. Thanks in advance.
Alex Stevenson
I couldn't find a repeat of this issue on the Interwebs and it's not mentioned in the Docs.
Duplicate post of this discussion found in other relevant forum:
https://community.cisco.com/t5/devnet-sandbox/application-package-signing-on-iox-catalyst-9000-sandbox/td-p/4438544
The issue might be this is being tried in a sandbox (VM) and Trust Anchor is rooted in hardware.
